Home My Page Projects
Support
First of all, check that your question is not already in our FAQ.
Then, you can submit a support ticket at the inria helpdesk portal (inria account is mandatory). On this portal, select "IT support request", then "ask for a fix" or "service request", and then select "services for research", then "inriaforge". You can also submit a support ticket by mail at address sed-forge.helpdesk-prc at inria.fr (this is the way to go if you don't have an inria account).
The old support email address help.et.gforge at inria.fr is an alias to sed-forge.helpdesk-prc at inria.fr.
When submitting your request, don't forget to provide accurate details of what's going wrong. Read, for example, How to Report Bugs Effectively.
Finally, you can also have a look at our bug tracker.
Presentation
InriaForge is a service offered to facilitate the scientific collaborations of people working at Inria (for more info, see the principles document). It offers easy access to the best in Git (as well as Subversion), mailing lists, bug tracking, message boards/forums, task management, site hosting, permanent file archival, full backups, and total web-based administration.
Participation in InriaForge
First timers should read "A gentle introduction to InriaForge" (aka InriaForge for dummies) to have ready info on the following:
  1. Private and Public projects
  2. Creating an account
  3. Creating a project
  4. Joining a project
  5. Configuring your ssh access
  6. Creating a code repository
  7. Configuring Eclipse to work with the forge
For those wanting more details there is a tutorial and before submitting a problem you might consider looking in the FAQ.
Site maintenance
Site updates happen on Tuesday mornings, around 9am. Service may be interrupted a few minutes on these occasions. Moreover, the webserver is restarted every night.
Latest News
First Kick-off meeting at Lille
Gang Zheng - 2019-10-02 08:18 - robocop
The Oct 17, 2019
Polyphemus-1.11.1 is out!
Youngseob KIM - 2019-08-09 16:44 - Polyphemus
Dear Polyphemus users,
Scotch 6.0.7 is out!
Francois PELLEGRINI - 2019-05-20 08:58 - Scotch
Scotch 6.0.7 is mostly a bugfix version. It provides some new minor features, such as an extension of the target architecture API and MeTiS v5 compatibility.
Annoucement: Secure cookies will be generalized for all websites from June 1st 2019.
Matthieu Imbert - 2019-04-12 07:51 - Site Admin
Warning: this announcement may require intervention on your part!
Polyphemus-1.11 is out!
Youngseob KIM - 2019-01-28 08:06 - Polyphemus
execo release 2.6.4
  2018-12-03 10:39
AWstats deactivation
  2018-11-22 13:20
SimGrid v3.21 released
  2018-10-08 11:31
Features Boxes
InriaForge Statistics
Hosted Projects: 10,055
Registered Users: 24,998
Top Project Downloads
804,598 OpenAlea
448,396 CGAL
392,477 Pharo
242,010 Dose: library and tools
232,494 iStoa.net
228,297 SPAMS - devel
223,185 Scotch
218,866 Cudf library
159,992 SOFA
144,747 MPFI
Most Active This Week
1 Belenios
2 StarPU
3 CGAL
4 MPFR
5 PM2: Parallel Multithreaded Machine
6 mmx
7 Padico
8 Why3
9 Modern C
10 MIXMOD
11 SPAMS - devel
12 Cudf library
13 IceSL
14 SmartEiffel
15 gazelle
16 Teaching at ENS Rennes
17 Flocq
18 MPFI
19 gf2x
20 Scotch
Recently Registered Projects
04/15 MADS
11/25 shnell - source to source compiler tools
10/01 robocop
08/01 HMD-TMO
07/12 SKINNY SAC 2019
06/30 GICS-HIL
06/30 MPI Introspection Monitoring
03/20 Deep4DCVT_release
03/04 CoIoT
10/23 jsexplain
All newest projects
System Information
InriaForge is running FusionForge version 6.0.5+autobuilt201809051346-1
This site is running FusionForge version 6.0.5+autobuilt201809051346-1
